OK, so i've mentioned this on a couple of thread's and asked on
other forum's but im getting a mixed and conficting response.
GSXR front end into Bandit 12.
I want USD so that rules out the early stuff.
Not fussed if its 4-pot's / 6-pots or radials.
Not fussed if I use the B12 or GSXR wheel as long as its a 3 spoke.
Do NOT want to go shorter than i have to,
DO want to keep the cable driven speedo as i want the B12 clock's
so needs to have same size spindle or have a speedo drive.
No problem with changing stem's, lock stops, bearings or making / adding top yolk or raisers.
I know anything will fit if you try hard enough,
but which is THE ideal front end to go for ?
A longer USD set with a 20mm spindle or one that has a speedo drive.
Im thinking late Oil or Watercooled 1100 ?
If so what year / model ?
