Fuel tank compatability, GSXR Oil burners
Hey all... anyone know which tanks fit the 91 model 750's?
Mine's bleeding onto the floor... it look like the seam at the front is gone... i'm thinking i might be able to hit it with one of those repair kits (the one's that line the inside with stuff)
but it might be cheaper (read "easier", fuck i'm lazy) to get a decent second hand job.
*mmmm hand job*...
All the sling shots and the first of the water cooler are pretty much the same ... 88 to 93? I dont know what year they changed the frame.
I think everything fits eachother until the srad's came out. water cooled tanks are a bit squarer on the curve of the rails.
if its leaking bad tank "kreem" may not work(mine still leaks a lil on full tanks).
88 ish- 91 should be the same. the water cooled gsxr's are a longer tank. i've tried to put my 91(oil cooled)tank on my 92(water cooled)
and was too short.
88-91 750 and 98-92 1100 are all the same.
I think Chase has one he might want to sell.
damn... i go to work for 12 hours and a million replies... thanks folks...
it's not leaking super bad... only on full tanks, and takes about two days of sitting on the side stand to start to show...
might give the tank repair stuff a crack...
thanks again guys...
