Shown at Ebay Germany
http://cgi.ebay.de/Tastensteuerung-S...QQcmdZViewItem
This Switchpack ist the Mastermind for your bike. If you building a new bike or upgrade your wireing harness this might be the answer. This Processor controlled Pack allows you to use very small impulse switches in your Handlebar to control your bike. With this small box you control your turning light, pass- and drive light, your kill switch, the startbotton and your horn. Everything is controlled by a internal security system witch checks your sidestand position or the neutral position of your gear during starting and driving. Your starter and ignition works only if the sidestand is in drive position or your gear is in neutral position. The turning light function can be used with LED or ordinary bulbs.
Additional this box switches the complete current of your bike. You need only a very thin cable to your ignition lock or your handlebar. So itīs possible for you to clean your handlebar from thick cables, use any kind of turning lights a.s.o.
Last but not least you have the possiblity to add an alarm system with an remote controlled starter for your bike. Just press an button on your remote control an your engine starts.
Any questions, send me an mail or use the Ebay mailing system.
