The project bike is now going to be sold off in bits
<s>The engine is a diamond it has gas flowed head,hot cams on slotted sprockets and kibblewhite valves,1216cc,new camchain and APE manual tensioner. APE studs and nuts,new genuine suzuki clutch plates,bandit 1200 gearbox and sump new main bearing shells while it was apart. The original tuning work was carried out by balls racing.$2200 ono offers
Includes starter motor and alternator but not the dyna ignition
I Rebuilt the Engine and it will require running in, buyer will have to organise pick up but I will help as much as possible as far as 200k's from 5126.on</s>sold to a very nice man in Darwin
<s>Wheels with good tyres including spindles and spacers,speedo drive and rear sprocket carrier the rear is a 5.5 $500 ono (not including discs)</s> sold
<s>Petrol tank no dents or filler $150 </s>on fleabay sold
USD forks including triples and fat bar risers and now includes a set of renthal fat bars $400
<s>Ohlins shock offers invited </s>sold
<s>CV carbies (set up to run with the pods and a straight thru pipe) with red foam pod filters $200</s>sold
Z650 duc tail fibre glass offers invited
<s>Stainless bandit 12 headers $200</s>sold
Lock set inludes ignition switch, petrol cap lock not the cap, seat release and of course a key $70
gsxr750 1989-90 frame and swingarm minus subframe has victorian single seat compliance plate offers invited
<s>Front brake master cylinder round with lever $60 </s>sold
rear brake master cylinder with braided line $45
<s>Left side switch gear $30</s>sold
Right side switch gear including throttle tube $35
Starter relay $20
<s>Fuse box $20</s>sold
<s>Dyna coils 2.2 ohms grey with leads $130 </s>sold
rear set left $40
rear set right $40
<s>Side stand including switch $30</s> sold
<s>clutch master cylinder (rectangle) with lever $60</s>sold to the nice man in Darwin
<s>standard clutch hose lobbed in with the master cylinder</s>Gone to the nice man in Darwin
<s>Engine mounts $100 </s>sold
<s>Chain and sprockets $50</s>withdrawn from sale as I have noticed the front sprocket is fucked
All the above is post extra and at cost no mark up on postage.
Stu
