Took the "effie" out for a run to Lobethal this morning and found the copper's had been there earlier checking bikes (parked at deli). A bloke on a Busa had been defected for ADR compliance (slightly shortened rear gaurd/pipe)has to go to regency for full inspection. The porker's had him sit on the bike to check he had no more than 45mm suspension travel (?),had him start the bike with side stand down then select gear to see if cutout worked! Dirty mud wallower's had a list of ADR reg's to check as well as the usual licence/rego/roadwothy requirements. All you "law breaker's" will be pleased to know that your tax dollars have been well spent as the cuntstable's were sent from Adelaide. No idea if this is a "blitz" or a one off "sortie".YOU HAVE BEEN WARNED!!!
