quote:
Originally posted by speeddemon
GSXR1100 whole front end but with Bandit 1200 stem pressed in:
forks gold valved and RaceTech springs 0.98 kg/mm (some marks on left leg) work well at speed but bit choppy at slow speeds - better than stock but could do with shim fiddling
6 pot Toki's
Standard GSXR bottom clamp
Custom billet top clamp to suit fork and will take standard bandit ignition and instruments
GSXR wheel (red) with axle and bearings and fairly new discs (the discs r bandit discs and r spaced out with washers not perfect but does job)
Was it turboKat? who expressed interest early on? and Davo expressed interest at AFR, so if they want it they get first dibs. But hey they may not be interested so let me know.
Straight bolt onto bandit or bottom clamp swap for GSRX1100.
$800 the lot - don't particularly want to part it.
