Sexy brake disc help
Can somebody please convert this to a file that i can use to get CNC plasma cut? Let me know what other dimensions you need.
I will use Bisalloy 360 for the contact area, but what should the center be? Can I use Al? Which alloy? How thick? Or am I better off using Bis for the lot?
Thanks.
James
Email it to me at ivanh@dyno.com.au and ill have a look see ... the center would be better made from al .. werd
usa-motorcycle-inc???? are you pinching the design from someone ???? if so im not up for it sorry
It's too low resolution to do anything with in its current state. It would have to be redrawn and would take someone a while to do.
Ivan is going to see if he has any already drawn plans that he can resize or whatever to fit my bike. I only used this picture because it is the only one I have found of a wave disc for my bike (GS500).
Any ideas what alloy to use for the center?
James
