Page 1 of 4 123 ... LastLast
Results 1 to 20 of 61
Thread: Clearing out some parts....... mainly GSXR
    Oct 2008
    Burpengary, QLD, Australia.
    Time to clear out some bits and pieces and want to give everyone here first chop.
    Have other bits & pieces that I will list as I get to them.
    Will keep bumping this here...... eBay can get farked atm.
    Open to offers
    2004-2005 GSXR750/600 pair of front fork legs, some light marks, straight and no leaks, 107mm c-c on caliper mounts - $350 the pair.
    <s>2001 GSXR750 Tokico calipers, 4 piston, good condition with hoses & partly worn pads, 63mm bolt spacing</s> SOLD - Apparently a great upgrade for VTR1000
    2001 GSXR750 Tokico calipers w/master cylinder and reservoir, 4 piston, good condition with hoses & partly worn pads, 63mm bolt spacing, no lever - $200
    2004-2005 GSXR750 Clutch cover, cable clutch, has sight glass installed - $50.
    1986-1992 GSXR750/1100 Clutch Cover, for hydraulic clutch, has sight glass installed - $50.
    1990 GSXR1100 gearbox, both shafts with gear, shift barrel, pushrods, no pitting on gears, shift forks not included, will need to replace sprocket side bearing on output shaft - $400.
    1989-1992 GSXR1100 Rear Grab Rail - $25.
    1994-1995 lower fork leg, USD, brand new in packing paper, 43mm OD on tube - $200.
    TL1000 mufflers, marked as SUZ2TL1000, a few road miles and marks but still good - $150 the pair.
    <s>2004-2005 GSXR750/600 pair of Radial calipers, gold finish, no pads or hoses, could do with a tidy up</s> SOLD
    2004-2005 GSXR750/600 pair of Radial calipers, gold finish, with pads but no hoses, could do with a tidy up - $80
    1989 GSXR750 sump/oil pan, drain plug threads good, good condition - $50.
    2001-2003 Yoshi EMS cube, has been used but in excellent condition, comes with discs and instructions - $450.
    2007-2008 GSXR1000 Yoshimura Dual TRC Slip-ons and link pipes, good nick but used, couple of marks, done bugger all kilometers - $650.
    2005 CBR1000RR Standard high rise under tail pipe - $100.
    <s>1990 GSXR1100 oil cooler, good cond, no leaks, bare without hoses, around $1k new from Suzuki</s>. SOLD
    1986-1987 GSXR750 bare cases with crank, good condition and suit rebuild, long stroke crank - $250.
    2005-2006 GSXR1000 Dynojet PC111 Part # 325-411, brand new in blister pack, never opened or used - $300.
    Adding more as I find them...........
    PM me if interested in anything and always open to sensible offers around the asking price. May trade for 90 or 05 GSXR750 parts.
    All parts don't include postage but can be arranged.
    May take a couple weeks to get them posted due to work atm.
    Badump bump
    Nother bump
    Bump again
    2004-2005 GSXR750/600 pair of front fork legs, some light marks, straight and no leaks, 107mm c-c on caliper mounts - $400 the pair.
    <s>2001 GSXR750 Tokico calipers, 4 piston, good condition with hoses & partly worn pads, 63mm bolt spacing - $100</s>
    <s>2004-2005 GSXR750/600 pair of Radial calipers, gold finish, no pads or hoses, could do with a tidy up, 107mm c-c on mounting holes - $75</s>
    2004-2005 GSXR750/600 pair of Radial calipers, gold finish, with pads but no hoses, could do with a tidy up, 107mm c-c on mounting holes - $90
    2007-2008 GSXR1000 Yoshimura Dual TRC Slip-ons and link pipes, good nick but used, done bugger all kilometers - $650.
    <s>1990 GSXR1100 oil cooler, good cond, no leaks, bare without hoses, around $1k new from Suzuki - $150</s>.
    Ippy, Qld, Australia.
    Oz do you have A TL top clamp?
    Nov 2006
    Chiswick, Sydney, Australia.
    And neatral sensor switch for a gsxr 89-92?
    Oct 2008
    Jay...... TL top clamp.....nope.
    Seifer... Neutral switch...will look.
    Aug 2007
    Watching all you fucktards
    SRAD 600 top clamp or one of those weird TL1000s plastic rear gaurd things?
    Needles and emulsion tubes for a 93 GSX-R750WP?
    Or maybe a set of carbs?
    Oct 2008
    EFE... no luck.
    Nitro... nope.
    Gsxr bits are mainly oil cooler or 2004/2005.
    Nov 2006
    Any luck with the switch?
    Oct 2008
    Seifer, yep, found one. Will need the wire fixed but the plate isn't cracked. PM me your mailing address.
    Brisbane, Queensland, Australia, Australia
    I have TLs tripples if that helps
    what marks are on the forks?
    they would be 50mm upper diameter, is the lower 54?
    could i get hole centre dimensions on the calipers pretty please
    Oct 2008
    Fimp,
    Marks on the forks look like they are from the clipons at the change of diameter at the top, a few clamp marks right at the tops of the outers and a cable clamp mark maybe below the change of outer diameter about 1/2 way down. The chrome of the slider is not damaged. Forks do not leak. Marks should clean up ok. You are spot on with the diameters of the outer tube - 50mm & 54mm.
    Gold radial calipers are 107mm c-c on mounting bolts and black normal calipers are 62-63mm c-c on the mounting bolts.
    Hope this helps.
    Jan 2009
    Melbourne, Vic, Australia.
    I'll take these: 2004-2005 GSXR750/600 pair of Radial calipers, gold finish, no pads or hoses, could do with a tidy up, 107mm c-c on mounting holes - $75
    Will pm.
    Oct 2008
    80s,
    Done. Waiting to hear from you.
    hi mate, one more question
    could i get the length from the top of the fork legs to the centre of the axle
    cheers
    Oct 2008
    Fimp,
    722mm from top of leg to centreline of axle.
    Nov 2006
    Hey mate, have you got any front master cylinder setups going. Preferably for twin 6 pots?
    Oct 2008
    Seifer,
    Will have a look. Did you get my email about the switch?
    Sep 2009
    Interested in the 01 GSXR front calipers. I live in Jindalee if you could let me know how you want to do proceed. Cheers, Jon
    Oct 2008
    Jon, PM sent.
