Results 1 to 7 of 7
Thread: Running problem
    ASF Standard Full Member Bob's Avatar
    Nov 2008
    Mt Cotton, Qld, Australia.
    Running problem
    Ok. My gs isnt running on one cylinder. Has spark and i assume fuel cause the plug is wet. But no fire. Any thing i can do before i crack the shits and send it to someone?
    ASF Premium Full Member LKC73's Avatar
    Nov 2007
    How's the timing on the trigger wheel for spark work mate? Maybe that is off wack and could be the cause. Also check the spark plug leads are on the correct cylinders.
    Monster GSXR 7/11 RIP!
    Raven R1 Demon.
    K7 750 German Style (under construction)
    Nov 2008
    It seem to be set at the stock setting. Should it be advanced or retarded for pods and dyno jett? ( tehehe retarded)
    Surely test one would be to swap them over and try running it quickly. If you only run it for a few seconds it shouldn't do any harm? well, if they are already on the wrong sides you can't do much worse. Did you keep a photo or drawing of which lead went to which during disassembly?
    Nov 2008
    One coil per cylinder. It was left to left and right to right
    Australia
    1 + 4 = pair
    2 + 3 + pair
    1 is left side of bike sat on and rest are numbered 2 3 & 4 to right.
    assuming it's normal Japper!
    Nov 2008
    Twin cylinder mate. But got it running now. Stubbled my way threw trial and error. Cheers for the pointers guys
