The new Busa already has a Power Commander, and quickshifters are cheap as chips. I like using them. Are they a straightforward any muppet with a shifter can add one type mod or are they somewhat more involved?
Look up boostbysmith and also ECU Editor.
Mine is good when just cruising but I haven't got back to getting it working when under full load high revs yet, it's still a bit "sticky" if you get my drift!
Also woolich racing, he's an Aussie and good stuff!
Cheers for the heads up Hagarr. I'll get onto them now
I couldn't get mine to work good enough for the drags and took it off. You need the power commander software to tick the switch in the power commander to turn it on too if I remember right
Woolich stuff is good, we've used it in the 750's, very easy
Interesting!
Mine works a treat when punching through gears at mid throttle but when WOT I haven't had great success and haven't gone back to attempt to rectify (Read too many projects)
I still use mine but for normal everyday stuff, will need to get my shit together and sort out.
Might have to look in to what you say about PC and switching there as well Stu, hadn't thought about that aspect!
I saw it on the Phil Tainton racing site which is why I asked about them. He uses the PC version
