Results 1 to 20 of 37
Thread: ZX10 injectors
    ASF Basic Full Member
    Mar 2005
    gold coast, Qld, Australia.
    ZX10 injectors
    Has anybody got 4 standard ZX10 early model injectors laying around collecting dust I can buy?
    Any model will do, I want to adapt and try them in the Z1 to see if it gets rid of the accelerator enrichment problem I'm having.
    Mark.
    I prefer it as it is; I can just about keep up with you.
    By the way, don't you hate it when you get excited that there is a reply with maybe some injectors and it's just me being a dick?
    Mar 2005
    Thanks Si. I was so overwhelmed buy the response I brought some off Ebay
    Is it fixed yet?
    Mar 2005
    Still waiting
    ipswich qld Australia
    Did you end up using the micro squirt unit mark?
    What about now?
    Mar 2005
    No not yet
    Still waiting for the pig tails so I can finish the wiring.
    Who can guess what I used to make the fuel rail?
    Yes Ozzy, Just changed the injectors, got rid of the 2nd tank and plumbed the return straight to the main tank.
ID:	6470   Click image for larger version.
    You should be a plumber mate!
    ....oh, and is it finished yet?
    Oh snap silver solder and copper so much win......
    Whole thing is so much win
    Do you find much diffrence with the injection over carbs ?
    ...what about now?
    Mar 2005
    Not yet Si.
    The injection feels a lot smoother, can't tell if it goes any harder, hard to tell, feels about the same at full throttle.
    Nice and don't worry that can always be reminded lol
    I have always wanted to have a go at the micro squirt looks a top unit
    Dec 2009
    brisbane, qld, Australia.
    Ha ha Luv that fuel rail Mark. Bloody tops ;-)
    Brisbane, Queensland, Australia.
    Come on Mark, surely there can't be anything wrong with those 30 year old injectors!!!! Lol
    Is the problem sorted out ?
    Yea, Dave's got a point. ........Is it finished yet?
    Mar 2005
    Yes Yes Yes, its not easy being a tight arse you know, its quite a challenge.
    No not finished yet Si but on Wednesday, I did make a make shift harness for the injectors (till I get the real thing) and went for a ride, it feels pretty good, very smooth at low speed, I need to get up in the hills and play with the accelerator enrichment to see if it has solved the problem I had, however I have created a new problem which I should have foreseen, when I brake heavily with less than a 3/4 tank full, the fuel rushes forward and exposes the fuel outlet and bingo, no fuel pressure, shit, so other than baffles in the tank, anyone got any suggestions?
    Surge tank?
    Dec 2009
    Longer hose between tank and pump?I probably have about a metre of 1/2" bore rubberpipe in a loop under the tank to the pump and it will run the tank virtually dry without any running issues.
