Results 1 to 20 of 37
Thread: forks
    Jan 2015
    Bowen, Nth Queensland
    forks
    Anyone got any suggestions for usd forks that might fit into the GPz 84 model not opposed to making new triple clamps to suit but don't want to go mad and buy the $2000 + ohlins
    Anything Modern will look the part..
    http://www.ebay.com/itm/ZX6-Front-En...fedf68&vxp=mtr
    Jan 2015
    Thanks bloke, much appreciated
    Yep, as Gitzy said mate. Once you get them it's just a case of sorting your stem out.
    Jan 2015
    Sounds good, hopefully will be soonish, things are pretty tight at the mo, I'm one of them lucky miner blokes that just recently got pay cuts an shit. Also trying to sell pre loved car bits but everybody else up here in same boat, with no disposable income.
    Jan 2015
    G'day all, another question, as you guys may have seen I got a set of 2003 ZX6R usd forks, now for you engineering guys, would it be ok to turn the head stem from 35 mm dia. down to 28 mm dia. or is better to get some 6061 round stock and make a complete new one?
    Cheers,
    laurie
    Quote Originally Posted by Barra58 View Post
    Cheers,
    laurie
    Need pictures on that one... Depends what is left of wall thickness etc and to turn a new one I only ever use 7075 t651
    Jan 2015
    Thanks OZZY, here is some pics, and yeah if turned down would only have 6 mm side wall thickness, um last pick is sort of what id need, with a 28 mm x i'm guessing .5 mm pitch would have to measure though and the other thread is 25 mm by same pitch, if you give me a ball park price + freight to Bowen, 4805, would be great, email is laurie_wyngaard@bigpond.com, and if your happy to do this i'll get you some better dimensions. I'd do it myself but to hard to get the ally up here and having to use other persons machine plus the get someone else to cut thread because the lathe I have access to is 50 years old!
    Jan 2015
    oh and thread pitch is 0.75 mm not 0.5 mm as that was a by eye guess.
    I don't think you want to pay what I'll charge you mate (400ish 50 of that just material with out postage)
    Why don't you look at using the stem out off the original with bushes and bosses some times that is feasible
    There are a few ways to go it, norm takes me a hr just to draw up what is needed for a new stem and that's with both old and new stem and new yokes in front of me.....
    Trust me take your time and look at it from a few angles
    Wait to you finish it and remember u need to do something with stealing stops....
    6 mm wall is almost ok btw but have you thought of opening up the yoke instead,
    Jan 2015
    yeah have thought about that, but removing, cutting & shutting, dunno, might have a bit more of a think about it, think outside the square. and yeah re using the old stem was my original plan, may go back to that, was just that it's an old heavy pos, but it will be easy to make a boss to go into the bottom clamp, don't have a top clamp yet going to get a bloke in Mackay to machine it up. and the old lathe will be ok for that part of it.
    Oct 2011
    Albion Park, nsw wollongong
    Any more done with your forks as I'm having a similar problem and would be good to see how you go?.
    Jan 2015
    ^^^ Yeah Bud, I ended up using the original gpz750 stem and machined a boss to press onto the stem then machined again to the correct press fit diameter and pressed it into the lower triple clamp, however when I get a lathe in the near future I will machine one out of ally which hopefully will be much better, followed the advise from ozzy
    Jan 2015
    Sorry guy's, got another question, probs will have many more before this pos is finished, anyway I bought a rear zx6r rear wheel and you guessed it, so does anyone know what swingarm will fit without to many mods preferably from the zx range of kwaka's.
    Thanks in advance
    Oct 2011
    I have parts off a 96 zx6r if that's any good to you.
    Jan 2015
    Swingarm with rear axle and swingarm axle/pivot, price and it would have to be freighted to 4805, Bowen, Qld so I guess some sort of guestimate on freight price as well
    Oct 2011
    I have complete shock if interested in that as well but no back axle.
    You're probabl past this point but aren't modern USD's a bit short to replace 80's forks?
    I'm used to Suzuki. Is kwaka different?
