Results 1 to 12 of 12
Thread: Custom cams ?
    Custom cams ?
    Yoshi cams for a GSX14 seem to go for over £500,
    knocking a hole in $1000 over here.
    How hard is it to get custom cams made if you have a set of genuine Yoshi cams to copy?
    Not just grinding or reprofiling, I'd imaging they would need to be built up? Hardened?
    No R&D required just a direct copy.
    Would you have to start from a blank?
    Can you build up and harden material?
    Who would you use and would it be cost effective (based on a few sets) ?
    More to the point.... dumb idea or practical alternative to Yoshi's ?
    Just buy the Yoshi can cost u up to 75 and no less than 50 a lobe for the regrind
    Depending on what needs done they need to be welded
    Only a few places left worth useing
    Have you looked at Webb cams out the states
    No, haven't tried Web but Yoshi's have a very good rep with the 14
    and the 14 wasn't sold in the US market so they have limited interest.
    Been told to try these guys.....
    http://www.tighecams.com.au/index.htm
    I wouldnt, old man tighe is one of the true legands of australian motor sport but it has been a long time from when he had anything to do with the biz.
    If you are intrested call me and I can make a few calls for u
    RUTHERFORD NSW
    well you have crane cams , crow cams
    to have a cam doctored is only $130.00 from crane cams in Sydney
    give kevin pryce a call from pryce engines in Newcastle a call and have a chat to him and he can tell you whom etc
    , Vic., Australia.
    Do a search for Livewire's post 'Tighe Cams - fuck em' Tony, IIRC he had some serious issues with their product.
    ASF Depleted Uranium Member Large's Avatar
    , , Kazakhstan.
    Quote Originally Posted by TurboKat View Post
    Yes this^^
    I was being more polite lol yes stay away
    Quote Originally Posted by Tony Nitrous View Post
    Hell no
    Brizvegas.
    I used to defend Tighes because I'd had no problems with the set of cams I just sold, and the cams in my car, but I've just stripped my motor down due to a disintegrating crank bearing, and discovered the set of Tighe weld and grinds that came with a head I bought had suffered heavy wear, and a couple of bits that have flaked off that look like they might have been welding flaws/inclusions. Now, I don't know how old or when they were done (I suspect they were done before the cams I had done, but hadn't seen allot of use before I used them), anyway, they've fucked out, so it seems I've had a 66% strike rate, 4 good cams, 2 not so good. Web also hardface some of their cams the same way, so who knows.
    what the mig with some hard face wire and a flap wheel isnt good enough ?
