KOSO DL03srp combined speedometer, rpm and warning lights
New from KOSO this combined unit features speed in Kilometer and MPH, RPM reading to 14k , 5 warning lights , fuel gauge and volt meter.
The unit is available with or without the stylish rear pod and included in the box is a handlebar mount, speed sensor, magnet and English instructions.
The RPM scale only shows when the engine is started..
http://www.digital-speedos.co.uk/dl-03sr-563-p.asp
http://www.digital-speedos.co.uk/dl-...sing-627-p.asp
Reason: Adding information
Thanks for that, we had the rear casing manufactured ourselves in the UK,
Its also a very slim gauge when its purchased standalone.
All this Digital Speedos stuff shits me a little bit as I've just bought a whole load of Motogadget stuff and might not have done if Digital Speedos had been a couple of weeks earlier in posting up on here.Ho Hum
