Hi gents,
Been on other forums for a while and decided i'd be better off with the cool kids here and maybe participate in some local events
My bike isnt exactley a fighter but i think it will still be of interest to some folk
Specs;
1988 GSXR750
3mm overbore using 05 ZX10 pistons to get low compression ( currently a bit low at 7.5-1) and forged pistons.
IHI RHB5 turbo, headers made from cut up 92 gsxr750 headers and 50mm pipe through to muffler and in built oil return to oil pickup but not a reed.
Microsquirt V2 EFI, using GPZ1100 34mm Tb's, GPZ750turbo plenum and IAT sensor, Mazda RX7 460cc injectors, homemade fuel rail, SARD FPR, Pierburg pump, GM copy 3 bar Map sensor and coolant sensor, Ford Edis type 4 post waisted spark coil and 8mm silicone leads and a Triggerwheels.com 36-1 trigger wheel fitted to the remains of the oem suzuki one.
Triumph SSSA and wheel with a Renthal 46T rear sprocket, a custom 16T 17mm offset front sprocket and a RSV1000 Sach Shock.
All this is my own work, the only thing that got farmed out was the block boring for the rebore.
Finishes are SH#t but once i get it all working i will look at a full rebuild and sorting it out propperly but will do till the bugs are ironed.
I'll just post a heaps a pics and let them speak for themselfs.
Cheers Peeps
Slingy
