7/11 owners may want to put this in their notes of da manuals.quickly, if you plan 2 adjust ya valve clearances or pop da head off,it`s usually "drop donk"(THE LOT)
I cheated 2day,cause i wood not take it anymore!
[8D]drop tank,carbs,undo rocker cover bolts.
now refer to manual,carefully remove inlet cam caps.
take out,1st"c",1st"d",2nd"d" & rear bolt on 2nd"c"
THIS with a steady hand will give you access to ya top end[
