Results 1 to 9 of 9
Thread: Oil temp?
    Benalla, Victoria, Australia.
    Oil temp?
    How hot is too hot?
    Seeing as I have an air cooled engine and the engine oil gets pumped through my turbo, it gets hot. I have a little oil cooler on there now from a 110cc dirt bike, (as i figured something was better than nothing) but the oil still sits around the 100 degree mark.
    What temps can oil get too before it fails to work properly?
    "It's the eighties and I'm down with the ladies"
    130 deg c is average breakdown temp of engine oil , more additives can drop or increase this "average temp" breef exposure to a temp above 130 will do far less damage than prolonged exposure to 120 deg c. The general consensus from my sorces is between 80 and 90 deg c is ideal but 100 is just fine mate oil cooler is possably a little on the small side.
    Just change it every 2500k's with a filter and all should be fine.
    my oil cooled bike used to run all day at 100 mate and i never had to much prob
    it was only after i fitted a temp gauge that i ever worried lol
    X2
    Use a decent synthetic oil like Mobil 1 and stop worrying.
    Sep 2008
    Ferntree Gully, Victoria, Australia.
    My oil cooled race engine regularly runs above 100C. In fact it is probably closer to 120C.
    Run a good oil and you should not have an issue.
    Indeed Mobile 1 is a good n High flash point etc etc if you want better (much) Amsoil but it will cost you, from someone like Autobla or superipoff it would be up around $100 a quart but this bloke can hook you up for alot less is going for around $11.50 a quart in the states. His web site (Aussie) has it at $16 a quart.
    Contact Info
    Mobile: 0414 369 926
    Email: sales@performanceLUB.com
    yer my bike in traff would hit 110 if not more with np
    red thats only about $50 to $60 per 4 ltrs not to bad if its that good
    mind u to rich for me just a good reg oil useing same brand every time changed with fitler ever 5000 kms(old bike) will do me fine lol
    If that's $16 delivered, bargain. Watch out for huge freight charges and restrictions.
    Mobil 1 is easy to find just about anywhere across the map. If you live in the middle of nowhere, the local Mobil servo or fuel depot can order it in for you.
    I think he is from Melb.
