Page 1 of 3 123 LastLast
Results 1 to 20 of 46
Thread: Making a crystal effect solution.
    Glasgow, Scotland, United Kingdom.
    I know this has been kind of put in another post but here is my experience with the crystal paint effect.
    ok, the crystal solution can be bought from alsa corp but it works out at £80 a quart to get it over here but will no doubt be cheaper for you guys. For the various effects you use different amounts of solution, mostly lots.
    There are 4 ingredients to the solution.
    Water
    Urea
    ammonia (not so sure if this is an additive or just present in the urea)
    neocryl (an acrylic copolymer used as some kind of wetting agent, it is in the form of neocryl bt-175 and this is made from 58% water 40% acrylic copolymer and 2% sodium lauryl sulphate(this is common in nearly all liquid soaps,used partly as a thickener. Anyway, not something that can be bought over the counter so i have looked for alternatives).
    Water from your tap (i will try bottled water and deionised water as well), ammonia from hardware store and Urea from a cleaning supply store or maybe a garden center. Urea is also present in cleaning agents as well as fertiliser and is easily available in prill form (small balls/granules)
    Im sure that where you get your Urea from will supply ammonia.
    Now you need to create a saturated solution. To do this i got a pint of water and added the urea untill it stopped disolving in the water. Then i heated the solution in a pot and added more urea until it stopped disolving. About room temp is all that is needed. I found that if too hot the urea will decompose and will not work. No point in adding urea to boiling water as it takes up to 7kg per liter and most of it will reform when the solution cools. I believe that the re crystalised urea will be a better form with less impurities, maybe better to use but i'm not sure. At 20*c water will take about 1kg per liter of urea.
    This was good enough a process to create a saturated solution(a chemist might have the right way to do it, so feel free to inform us )
    Ok that is the crystal solution ready but if you pour this over fresh dry paint it will bead on the surface. To stop this we add the ammonia, this seems to act as a wetting agent to break water tension and allow the solution to pool over the surface and stick a tiny bit better. I will experiment with other surfactants, washing up liquid,washing powder. This is why i think the alsa stuff has the neocryl bt-175
    I used 70% crystal solution to 30% ammonia. This worked for me but experiment for yourself as you may need more or less ammomia. It does seem to take longer to dry with more ammonia. Good, bad, i will let you know later. EDIT: It does not require a lot of surfactant maybe only 5ml per 100ml.
    Now apply your base coat, this will be the main colour of the finish depending if you candy or not.
    once dry there are a number of ways to proceed.
    you can clear over the base as this gives a good surface to key up heavily in many directions. This way you can almost control the forms of the crystal.
    Or you can key/scuff up the base coat itself OR you can just leave the base coat. It is up to your self to try this out.
    Now apply the the crystal, i just pour it on as it is cheap as if you make it your self £2 ish a pint. Others use a spray bottle to apply it. Either way is good. A thin layer of solution will give a thin crystal form and a thick layer will give a thick crystal form.
    Now leave to air dry in a warm room for large finger fromations or force dry for tighter smaller formations. I prefer air dry.
    As it dries you will see the crystals form, quite cool to watch the first few times.
    Let it dry out fully about 15 mins to an hour depending on the temp and thickness of application.
    Now it is time for the contrast coat, i use black as it seems to be more dramatic. This MUST be applied in a light dusting fashion, NO heavy application as it will melt the crytsal and make it difficult to remove later.
    1 light coat will give a shallow 3d contrast and a few light coats will give a deeper 3d contrast. For the best result i found that NOT applying even coats of black is best for giving varing depth of finish. Once the top/contrast(black for me) coat has dried you can then remove the crystals by washing with water and a soft cloth, try not to rub to hard. If the crystal is being stubborn to remove then LIGHTLY wet sand with 1500/2000 grit.
    Now that it is clear of crystal and dried you can apply your top coats be they candys, pearls or just clear coat.
    EDIT: Raising the point of safety when mixing chemicals, I believe that you should only attempt this if you have researched the materials you are using and have COMMON SENSE I doubt the mixes i'm using are explosive or toxic (other than usual ammonia vapour and spay) but remember to be careful.
    Urea reacts with calcium hypochlorite or sodium hypochlorite to form the explosive nitrogen trichloride. It is incompatible with sodium nitrite, gallium perchlorate, strong oxidizing agents (permanganate, dichromate, nitrate, chlorine), phosphorus pentachloride, nitrosyl perchlorate, titanium tetrachloride and chromyl chloride. PLEASE AVOID THESE WHEN MIXING WITH WATER!!!!!
    It does contain ammonia which smells bad and is irritable . Ammonia solutions should not be mixed with halogens( fluorine (F), chlorine (Cl), bromine (Br), iodine (I), astatine (At), as toxic and/or explosive products are formed. The urea/ammonia mix is good for your plants........but if for some reason you mix it with bleach (one of the 1st things i thought of doing ) then it can release a chlorine gas which it bad bad bad (seriously)
    just a quick note that the crazer effect that alsa sell can be replicated using fine rubbing compound over a base coat then contrast coated washed down and top coated/cleared
    Might not be as good as the crazer but well worth the effort to try. Another cool effect is the marbilizer from HOK (house of kolor)
    Note that all of theses effects need shit loads of clear coats to build up the layers as they are tactlie finishes. Lots of clear allow you to wet sand and polish and create fantastic and unique paint effects.
    Another note is that the crystal finish is organic in style and almost impossible to create the exact same effect. So it is best to do large adjacent panels at the same time as the air flow and temp will be the same.
    Any way perhaps that will make it easier for ppl to grasp if they are just browsing the site.
    Sorry, for once no pics maybe when i do my lid [8D]
    Eh?
    Can you point us at any examples of what crystal paint is?
    I'm too old to know about such things
    brisbane, qld, Australia.
    This is what happens when you use crystal...............
    [xx(]
    melb, vic, Australia.
    thats what he means by crystal paint... looks pretty crazy if you ask me..
    or maybe this one you like...
    Niice
    Wagga Wagga
    Id love to have this type of effect on that 2006 SV6 blue commodore colour on my bike... long way off yet as need to get bike to my final stage before worrying about paint lol...
    Jarrod
    im thinking about doing my RR in this type of effect, but it stands out like donkeys balls... nice and easy for cops to recognize, and thats not cool...
    quote: just a quick note that the crazer effect that alsa sell can be replicated using fine rubbing compound over a base coat then contrast coated washed down and top coated/cleared
    I'm looking at doing the crazer effect... but that doesn't make much sense to me - maybe its the afternoon drinks... can you re-essplain for me? I would mucho appriciato
    Aug 2006
    Central Coast, NSW, Australia.
    very nice 44 gal drum mate
    Jan 2007
    Pacifica, CA, USA.
    Top Class, Thanks, Might give this a go..
    i wish i had one...[V]
    use a good bodyshop[silicone free and water based] cutting compound (fine paste not liquid) and put some over your basecoat, now you can distort the surface of the paste with a rag or cling film(food wrap) or tin foil. remove the wrap(or what ever you used) then dust your contrast over that. when dry wash down with water and finish with candy or clear.
    It can aslo be done using a very wet coat of paint and a plastic bag or wrap. However i found that i could only do this on small panels as the basecoat i used dried quite fast. I have used both of these with good results and all look like the HOK marbilizer, Alsa crazer and rage marble paste.
    You don't have to be a pro to get great results, if you can wave a spray gun then your half way there.
    If you're interested in theses paint effects check out some airbrush forums. I've been browsing them for the last couple of years, plenty cool stuff but most air brushing is beyond my skills for now
    Shepparton, Vic, Australia.
    How would plain salt go for a finer effect, crystals are smaller than urea.??
    Bloody great effect !
    Also if anyone wants urea and can't find it at the local nursery/plant specialist i buy it by the truckload .
    Brilliant - thanks cammy - I'm going to have a crack this weekend just for a bit of practise - the 12r is shortly going to get a new paint job in time for fools run
    Hey booster? Who's your supplier? Osama? I have a truck load of diesel if you are interested
    Hey Pete! Let me know hw you go mate or let me know if i can bring over some ales and watch ya do it learn for when the Duke Tank is repaired!
    Used to remove trees with a bit of ammonium nitrate and diesel, can't buy the good stuff anymore
    urea is for spreading on the ground.
    PM'd you Boh
    Blacksburg, VA, USA.
    i noticed in the how to section the pices looked grainy. how many coats of clear have to be used to smooth this out? Also have you tried or seen any pictures of this done over multiple colors? For instance my tank is 3tone and i was wondering how the crystal would look on that.
    this is what efect you get when you do the plastic bag way
