You lifting it or are they to compensate for a different length shock?
The bike falling over unless I watch where I park or put the block I carry
Under the stand not so much lol
what is the difference in fork lengths?
so you are 60mm lower at the front, and 7mm higher at the back. might be a bit twitchy.
Attachment 8162
Removed subframe, R6 subframe should arrive this week
This will be cool! Looking forward to the updates.
Committed now mate! Good stuff.
Looks like you're all in for the tail swap; like I king forward to the progress on this one!
Attachment 8163
OK, I need your thoughts, my original swingarm pivot bolt is a smaller diameter than the 05 pivot bolt.
However, the threaded ends of the o5 pivot bolt is too small a diameter for the 89 frame.
I am thinking of getting a sleeve made for the 89 pivot bolt so it fits the o5 swing arm but unsure who can make one.
I'd say Travis would be your man: https://www.facebook.com/Hammeng/
